110cc syloinod problems?
Old Jan 19, 2015 | 04:22 PM
MPDano's Avatar
Originally Posted by bdelancy
i will try jumping it off my truck and see what that does for me if that works do i just need to get a bigger battery
No, just the correct size that fits in your quad. Yeah, report back as using your car battery will be a good test.
Old Jan 20, 2015 | 08:54 AM
bdelancy's Avatar
so it started when jumping off my truck... good news
at idle it ran fine as i increased the throttle it started popping if i gassed it to full throttle it dogged out so i tore down the carb and cleaned it (looked pretty clean) put it back on hooked it back up not getting and power at all past solenoid no lights no gear indicator nothing could a bad stator cause complete power loss
Old Jan 20, 2015 | 10:51 AM
MPDano's Avatar
No, a good battery will keep your ATV running. Sounds like you disconnected/misconnected something while R&Ring your Carb.
Old Jan 23, 2015 | 11:17 AM
bdelancy's Avatar
well the bike will turn over now if i cross over the post on the soleniod but i have no lights anywhere when the engine is cranking the indicator light will light up but when its not turning over no lights could this be a faulty key and tumbler
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Waddell4436
Jul 20, 2015 09:46 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
musselmark
Jul 17, 2015 02:40 PM
