1987 lt300e
Old Apr 14, 2015 | 08:07 AM
Lewis F Williams's Avatar
Default 1987 lt300e
New fuel pump... carb cleaned but not rebuilt...
Good gas ... won't fire..
Tries harder when throttled..
But won't fire..
At my wits end.... help!!!
Old Apr 14, 2015 | 08:27 AM
Scooter86's Avatar
Knows Old ATV Questions!
Do you have spark? Fuel flow to cylinder? Fresh gas? What things have you already tried?
Old Apr 14, 2015 | 09:23 AM
Default scooter
Has spark....seems like gas not getting there to ignite...bowl has gas in it...
Old Apr 14, 2015 | 09:34 AM
Scooter86's Avatar
You can remove the plug and pour a little bit of gas in the cylinder. Replace the plug and it should start if only momentarily. That would tell you if you have a fuel flow issue. If it has sat for a while, did you remove the jets and clean them out also? The pilot is susceptible to clogging with old gas varnish or even dirt/gunk from the tank or float bowl. I would probably pull that pilot and check it as the next step.
Old Apr 14, 2015 | 09:58 AM
Default scooter
Old Apr 14, 2015 | 10:00 AM
Added gas .. did start.....pilot removal???
Old Apr 14, 2015 | 10:10 AM
Default scooter
Old Apr 14, 2015 | 10:27 AM
Default scooter
Did remove and cleaned jets ...It ran... but realized
I had the fuel and vacuum lines reversed..started smoking..
Reversed lines and ran till smoke stopped...3 minutes or so..
Turned off ... Tried to star again 20 min later .. not starting...
Clean jets again???? Or am I up a creek??
Old Apr 14, 2015 | 01:12 PM
Scooter86's Avatar
I am not sure what you mean by vacuum line? Apparently this machine has a fuel pump, could this be what you hooked up backwards?
Old Apr 14, 2015 | 06:38 PM
MPDano's Avatar
Fuel system diagram.
Suzuki ATV Parts 1987 LT300E FUEL TANK Diagram
Diagrams of your bike:
1987 Suzuki QuadRunner (LT300E) OEM Parts, Babbitts Suzuki Parts House
Carb specific. Remove bowl and there are your jets.
1987 Suzuki QuadRunner (LT300E) CARBURETOR | Babbitts Suzuki Parts House
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
Steeldon
Sep 8, 2015 10:51 AM
Bulgin88
Jul 30, 2015 05:20 PM
Stillonit
Jun 18, 2015 11:23 AM
