TaoTao 110CC No spark
Old May 10, 2015 | 08:34 PM
Brandon Benson's Avatar
Default TaoTao 110CC No spark
Hello, new to the group... read through the sticky but couldn't really find my problem in there. Anyway, I got this secondhand ATA-110H1 single speed auto, 107cc quad. It didn't turn on or start or anything at all when I got it. Got the remote control to function, the kill switch and both front-rear brake switches working, remote start and handlebar start to work. I checked the ohm-readings on the pickup and everything seems fine, though when I do the engine-cranking test with my voltmeter set to the AC 200v range (it has 4 digits so smallest reading possible is .1v increments) and I get no reading at all except for when I quit cranking I then get a small pulse. I got a 133ohm reading on this pickup coil.
Can I get a seemingly-good ohm reading on the pickup coil and it still not work?
please help! ANd thank you so much for taking the time to read my post.
Brandon
Old May 11, 2015 | 08:15 AM
MPDano's Avatar
Sounds like a bad stator.
Old May 11, 2015 | 04:34 PM
I just found it odd that the pulser coil, or pickup coil, would have an ohm reading in the correct ball-park but have no activity when the flywheel spins... Thought I would check here before ordering a new stator to see if anyone else had this problem. Is there anyone that sells just the pulser/pickup coil separately from the rest of the stator? Seems a waste to get new lighting and cdi power coils for no reason, mine both checked out good :S :S :S
Thanks for your time
Brandon
hugemoth
Jul 20, 2020 03:28 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Bob Maurice
Jul 14, 2015 09:05 AM
Unzzy66
Jul 11, 2015 10:01 PM
