Tao Tao 125 Wont start
Old May 14, 2015 | 11:19 AM
brinkkl2000's Avatar
Default Tao Tao 125 Wont start
I have seen several threads on this topic, but no one seems to tell whether there issues were resolved, and I have tried every suggestion I have seen. So, now I turn to the experts.
It flat wont start, not even with starting fluid. I have gone through the carb a couple times and have fresh fuel in it. I have, what looks to be strong, spark by grounding the plug against the block. I have tried a new cdi, new plug, new battery, and new ignition coil. I have adjusted the valves. Compression feels so so with my finger over the hole, but with my compression gauge it is showing 50lbs. It is an automotive style gauge with about a 15" hose on it. I have been told before that because these engines have such a short stroke an auto tester may not be accurate, but I don't know if that is true. I did test it with wot throttle as well. The trigger coil tested at 122ohms.
Any other suggestions? The compression is suspect, but like I stated I don't know if my tester will produce accurate results.
Old May 14, 2015 | 09:30 PM
MPDano's Avatar
50 lbs is not enough. I had 60 in my ATC and it wouldn't start. Looks like your doing a top end rebuild.
Old May 15, 2015 | 06:39 AM
Jaster94's Avatar
Minimum of 95 psig for compression
Old May 15, 2015 | 07:33 AM
What about the fact that I used a tester with a long tube on an engine with a short stroke? Or does that matter, ie 50lbs is 50 lbs no matter what tester I use
Old May 16, 2015 | 09:56 AM
Jaster94's Avatar
Correct, not much pressure drop, 50 psig is 50 psig, (pounds per square inch gauged).
Old May 16, 2015 | 09:57 AM
Jaster94's Avatar
I have 2 testers, a short stubby insert 2" long & the other has a 17" tube, both register the same when I use them
Old May 16, 2015 | 03:31 PM
It would only make a difference if the one way valve was at the gauge end of the pipe. The valve is usually at the plug end. It may take a couple of extra turns of the engine if you have a long pipe though.
Old May 29, 2015 | 10:44 AM
In case anyone wonders, I did find the problem. Had to pull the engine and found that the wrist pin keeper came out or was never there to begin with came out and the wrist pin beat the crap out of the piston and cylinder. Gotta love these Chinese engines...
Old May 29, 2015 | 10:50 AM
MPDano's Avatar
The only good thing is that those top end kits are fairly inexpensive. I've seen them around $100 for everything and all you got to do is assemble it.
Old May 29, 2015 | 11:24 AM
MPDano's Avatar
Like this one off ebay for $85 shipped. If you do order this, verify this is for your 125 first.
http://www.ebay.com/itm/54mm-Big-bore-kit-change-110cc-to-125cc-Dirt-Pit-Bike-ATV-Go-Kart-Kazuma-Taotao-/281571262570?hash=item418ef4806a&vxp=mtr
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
