Ata 110 throttle cable
Old Jun 2, 2015 | 04:40 PM
Quadknewbie's Avatar
Default Ata 110 throttle cable
So I took off the carb and cleaned it out and in doing so I just took the throttle cable out of the box on top of the handle bars. Now my throttle is non responsive. Can anybody help me on routing the cable and maybe adjusting it when I get it back on?
Old Jun 3, 2015 | 02:59 PM
sae156's Avatar
when you say non-responsive, do you mean it's not opening or closing the throttle at the carb? if you post a pic, i'll compare it to my 250 and see if i can help.
Old Jun 3, 2015 | 05:04 PM
I finally figured it out. It needed the gas tank setting on it and there is a small cut out on the bottom for it to run through and it works fine after I got it ran. Now my question is, my handlebars are turned to the right a little bit after I straightened the steering shaft a little. Can I use the tie rods to correct it? And my left front tire is setting crooked on the ground. Is there anything I should look for? I see no broken or bent parts.
Old Jun 5, 2015 | 09:58 PM
MPDano's Avatar
Yup, you answered your own question.
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
craacker
Sep 9, 2015 04:32 AM
byronman
Sep 6, 2015 06:34 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
