Kazuma Falcon 110-4SAR troublshoot (wont start)
well when i read it lol it looks normal and somehow merryman read it and figured it out so i meant some people will not be able to understand it so i re wrote it.plus it had 200+ views so i figured out of those others werent able to read it as well.
and i think you are taking the words out of context it is not directed at anyone or group of individuals since you put it in quotations
figured it out if anyone happens to drop by this post and has same problem remove your starter clutch the spring loaded pieces seized up and rusted with some wd40 i loosen them up and cleaned it up and reinstalled back on quad fired right up. found this after taking completely apart
have a good one
have a good one
Glad you found it, like I wrote earlier, only the person looking at the parts can judge if they are "right" or not. With some faults we can suggest a cure because we have had the same fault ourselves. With some we can work them out logically, but sometimes it is a case of take it apart and check the components for faults.
