Smc Ram R100 Electrical issue
Hi
Ive replaced the cdi unit on my smc ram r 100 quad bike as it was faulty and I had no spark.
If have a good spark now and the quad runs well. Apart from two small problems.
I have a start button also red rocker and in the middle a safty tether which you pull out if you fall off.
There are 4 wires on the switch blue and white black and white and two solid blacks. On the quad loom i have blue white, black white and solid blacks. I have to hold in the pin on the tether ( tether cord wasn't with it) to kill the engine which seems backwards to me.
Second issue is it makes a noise when it tries to start. similar to when you crank a car and leave it cranking while engine is on sound.
stripped the motor all is ok also the starter and that's fine to any ideas
cheer's guys
Bigkev
cheer's guys
Bigkev
Yeah could do I guess. But wanted to try get all the original stuff working. The switch works just that you push and hold it in to kill it.
