110cc Chinese Quad won't crank
Old Nov 27, 2015 | 09:16 PM
Bjg5240's Avatar
Default 110cc Chinese Quad won't crank
Hi guys, new to the site. Hoping for some help with a 110cc quad I acquired that no longer cranks.
Quad was running fine albeit very tough to start when it's cold. One particular cool day it just would not fire up. Tried starting it so much that I overheated the starter and something let out a puff of smoke near all the wiring. Now the Quad won't crank at all. Just get a clicking sound from the solenoid. Replaced the solenoid, starter and tested the battery and it still does the same thing. Tried bypassing the solenoid and nothing happens. Thought maybe the wire from the battery to the solenoid fried because the casing was melting but that didn't fix the problem either. In line fuse is fine too. Any help would be much appreciated. Getting to the point of rolling it to the curb for trash day.
Old Nov 28, 2015 | 02:44 AM
Chinese starters are poor quality so you may have bought a dud. However, check all earths, check the battery is charged, sometimes brand new ones need charging. If all is OK and it still wont turn over, remove the starter and power it up on the bench. If it works, check the engine isn't seized by turning it by hand.
Old Nov 28, 2015 | 09:35 AM
MPDano's Avatar
Flooded by all that cranking? Remove the spark plug and try and crank it over.
Old Nov 28, 2015 | 07:41 PM
Bjg5240's Avatar
No, starter won't turn at all. Just clicking from the solenoid. Bench tested the starter and it's fine. Also check the ground wires and couldn't find any issues. Puzzled at this point.
Old Nov 29, 2015 | 10:19 AM
MPDano's Avatar
As suggested, try to turn over the motor by hand. Sounds like it's seized up.
ultangler
Nov 30, 2024 01:35 AM
RidingDirty400
Oct 8, 2015 09:36 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
Albertaboyy
Sep 9, 2015 09:51 AM
