Chinese 250cc twin ignition problems
Old Nov 29, 2015 | 11:53 AM
wightnewt's Avatar
Default Chinese 250cc twin ignition problems
We have a Chinese quad (no name) it says 250st in camouflage colours. Good spark to 1 cylinder but no spark to other cylinder. We have swapped coil packs over and they both work on the good side but not on the bad side which sort of indicates the CDI unit the unit we have is a CBT125 2 connector 1 4pin and 1 2 pin. Can't work out how the CDI distributes the spark to the appropriate cylinder we have replaced the CDI with the same as above with no change but can't guarantee that the CDI on the bike is the correct CDI. Can anybody help
Old Nov 29, 2015 | 01:19 PM
MPDano's Avatar
Google search: https://www.google.com/search?q=250s...8#q=250st+quad
Pulls up a Quad make Lifan
Engine manual but has some electronics in it. CDI shows a 6 pin, Rectifier has 2 plugs
http://mefast.com/LIFAN/Owner/Engine...50ST-50001.pdf
http://mefast.com/LIFAN/Owner/WCLF250ST-50001Engine.pdf
Old Nov 29, 2015 | 01:22 PM
MPDano's Avatar
A video:
Old Nov 29, 2015 | 01:24 PM
MPDano's Avatar
eBay pulls up a lot of parts for it. They even have a complete harness with all the electronics.
Lifan 250: Parts & Accessories | eBay
Old Nov 29, 2015 | 01:27 PM
MPDano's Avatar
V-Twin CDI looks it has 2 plugs, each have 4 pins.
CDI ECU Yamaha XV250 VStar Vthunder Colt Lifan Rhino Hunter Keeway 250cc Chopper | eBay
Old Nov 30, 2015 | 03:01 AM
wightnewt's Avatar
Thanks MPDANO Ours is a parallel twin not a v twin but looks very similar to the one you pictured.
Old Nov 30, 2015 | 06:09 AM
wightnewt's Avatar
Default Now have a spark
Update on the lost spark we have linked across from the sparking side (pre Coil) and it now runs, which indicates we may have the wrong CDI (CBT125) I guess the system is what they call a wasted spark. Can we leave it like this or will it damage the CDI.
Old Dec 1, 2015 | 04:00 AM
All quads seem to be "wasted spark" the only single cylinder bikes I have come across that were not are the old 200ES Honda three wheelers. I would have thought that the standard set up would be for either the CDI to fire both coils from one wire, or a two HT lead coil.
Old Jan 16, 2021 | 07:28 AM
jasonwarrens@yahoo.com's Avatar
Default Twin Coil 250cc wiring harness
Hello everyone, I am in search of the correct wiring harness for my “what I was told 250cc” The motor it has is a twin motor that has 2 spark plugs that connect to 2 separate coils yet every wiring harness I find doesn’t match up. Please let me know if you have ever run into this or know where I can find the correct harness. Thanks
Old Jan 17, 2021 | 03:56 AM
Sounds like an old Quadzilla 250, they used what looks like the standard 6pin Chinese CDI to fire two coils from a single CDI output pin. It isn't a standard CDI by the way as the pin out is peculiar to Quadzillas. They marketed the same bike under the RAM badge too. Quadzilla UK gave me no backup when I had ignition problems with one. So I would guess it is the usual zero spares backup situation with them. Fix your existing harness and forget trying to get a new one.
loli1976
1) Engine problems..
Jan 29, 2017 04:42 AM
Jason Dueitt
Technical and How-To Articles
Dec 31, 2016 05:07 PM
Shelite
Apr 30, 2014 06:13 PM
mudmike
16
Dec 22, 2012 11:19 PM
