GY6 150cc.engine won't start
Old Oct 17, 2016 | 08:06 PM
groovie1955's Avatar
Big Daddy Mike
Angry GY6 150cc.engine won't start
I've replaced Pick-up coil,ing. coil,CDI box,plug wire and plug,and Carb.It's in time,getting gas, firing,100lb of comp.,and valves set at .004...I've been a mechanic for 45 yrs. but this is my first GY6,and it has fried my brain..I need help...
Old Oct 17, 2016 | 08:31 PM
Does it even try to kick off with starting fluid?
Old Oct 18, 2016 | 01:05 AM
Big Daddy Mike
Unhappy GY6 150cc won't start
sometimes it will sometimes it want....
Old Oct 18, 2016 | 09:15 AM
Zrock's Avatar
Super Quad Patrol
go through your fuel tank and fuel shut offs. Clean them out as well as tear the carb apart and clean it out. Going through the sorta the same thing. when and if i can get it to start. Just put a new carb on with the same symptoms so i figure ether the fuel shut off gaskets are coming apart or their is crap in the tank.
Old Oct 18, 2016 | 11:01 AM
Big Daddy Mike
Angry Gy6 150cc engine won't start...
It's getting fuel ,the plug is wet...Everything that is supposed to happening is,except for running....
Old Oct 18, 2016 | 11:47 AM
Zrock's Avatar
Super Quad Patrol
Idle jets could be plugged with crap.
Sofa
Nov 10, 2016 12:38 PM
bvolks
Oct 14, 2016 11:23 PM
Outdoordave
Yamaha Side by Sides
Sep 25, 2016 07:53 PM
Lynnard
1) Engine problems..
8
Sep 23, 2016 09:23 AM
