need a christmas miracle please help
Old Dec 14, 2017 | 09:39 AM
Zrock's Avatar
Super Quad Patrol
Have you done a compression check? this will also tell you if your timing is off if you have low or now compression, or it could be time for a upper end rebuild. Have you pulled the flywheel off and checked to see if the key was sheered off. No point in speculating until you check
Old Dec 14, 2017 | 10:49 AM
newmoney89's Avatar
Have done a compression check getting 150 out of each side give or take a few pounds haven't taken the flywheel off yet I do not have a flywheel puller all I have is three jaw Pullers can I remove with one of those ?? It just seems strange that I'm only getting it's a fire out of the right carburetor and not the left seems almost like a spark issue which would either lead me back to you that flywheel being spun around or something else the coils don't look like they're in that great a condition in there kind of beat up I have new ones on the way and I have a new CDI box on the way I figured I'd throw some cheap parts at it
Old Dec 14, 2017 | 01:04 PM
hugemoth's Avatar
Don't use a 3 jaw puller on the flywheel, you'll break it. You can use a bolt of the proper size screwed into the center hole in the flywheel to pop it off.
Old Dec 15, 2017 | 02:56 AM
I had a newish Suzuki 500 KQ that broke it's key and spun the flywheel exactly 180 degrees out, and a Honda 200ES (ATC,) last week, that had sheared the key too, so it isn't unheard of. Like hugemoth wrote, you need the proper puller, usually a screw in or on type with Honda based engines.
Old Dec 15, 2017 | 01:36 PM
  #15
newmoney89's Avatar
Post
Update: the quad is running apparently it never had a keyway at all it was just a tapered shaft i removed spun around the tightened back down fired right up
so heres the new problem its only running on right cylinder the left is dead i have good compression seems i have spark although wire is messed up i have new coils coming if your riding it it boggs badly and then randomly the left side will fire and it will take off without the left side firing its hard to even get going at all and you have to stay in first lol carbs have been removed and cleaned twice it just seems weird that it just randomly works while riding and then dies back down when idling its all over the place sometimes its smooth sometimes it revs itself up sometimes it stays at high rpms or a second before returning back down ive replaced filter gas line petcock and all clamps dumped gas out and put premium in i will try swapping which coil is plugged where to see if problem moves when i get home thank you
Old Dec 16, 2017 | 10:39 AM
  #16
LT80's Avatar
LT80 Expert
Dude, a comma or period every now and then sure would make it easier to understand.
bradb1973
Dec 15, 2009 03:56 AM
wizard1212
Dec 2, 2007 04:45 AM
hondahotshot
Dec 4, 2005 05:59 PM
DemonDS
Nov 28, 2005 02:23 AM
RickRitter
Dec 31, 2000 11:55 AM
