New chinese atv 150cc
Old May 31, 2018 | 09:22 PM
Yukon2's Avatar
Default New chinese atv 150cc wont start
Was working just fine and now it has stopped, when you turn on the ignition the neutral lites up for a less then a second and goes off. I can jump it with starter solenoid and everything comes on put did notice the break light didnt light up when hitting the break and the lights were pulsing
Old Jun 1, 2018 | 02:32 AM
Bad connection somewhere. Could be the ignition switch, but could be anywhere in that main thin wire from battery to fuse to ignition switch. Check frame earth too. You must have a good earth to engine, as the starter motor works when jumped, but to frame?
Old Jun 1, 2018 | 09:40 AM
Yukon2's Avatar
bought a new ignition switch and tried still same thing, has to be after the ignition switch
Old Jun 3, 2018 | 02:56 AM
After the switch, the wires start to split up to go to start button, horn and lights (if fitted). So the fault has to be before that. My guess would be bad connection at fuse.
Old Jun 4, 2018 | 07:14 AM
Yukon2's Avatar
yep that was it fuse looked fine but when tested both sides one side was fluctuating thanks for the help, now i have another issue it seems i fried the switch for the lights not sure how that happened so i am not getting spark now so ordering extral parts for all electrical components.
4thgenceli
1) Engine problems..
Aug 29, 2014 07:06 PM
rjanderson9
Jan 9, 2013 06:05 PM
Malamute
16
Nov 3, 2011 10:51 PM
arctic_fox
Jun 20, 2007 09:45 AM
DrFfreeze
Mar 25, 2007 10:28 PM
