Chinese atv runs on old cdi but not new ones 5 pin
Old Aug 14, 2018 | 03:11 PM
mack4's Avatar
Default Chinese atv runs on old cdi but not new ones 5 pin
bought 2 atvs 1 ran right out of the box the other didnt
tracked it back to the CDI swapped the CDI out of the running bike to the non running it fired right up
Bought 3 5 pin CDI's from diff locations none of them will start the bikes but they continue to run with the old CDI as i move
them back and forth to the bikes
HELP what am i missing here
Old Aug 15, 2018 | 02:25 AM
It isn't just a case of pin numbers that need to be the same. I have known DC CDIs with 5 pins, and some kill wires are earth to run, some earth to kill, on AC systems. The most common 5 wire is AC, earth to kill, but if your 2 ATVs are of the AC earth to run variety, for example, three earth to kill CDIs which is probably what you bought, are not going to work. If you have a wiring diagram, you can work out which type of ignition you have. Alternatively , with new CDI fitted, ignition off, short across solenoid so starter motor turns, if the bike fires up and runs until you switch ignition on, you have bought the wrong CDIs.
Old Aug 15, 2018 | 08:02 AM
mack4's Avatar
merryman
thank you for your input this has been driving me nuts, i will give this a try when i get home today.
if this is the case how do i go about getting the right CDI
No one has asked me these questions AC or DC, Earth to run or earth to kill
just how many pins
Old Aug 22, 2018 | 11:27 AM
mack4's Avatar
Merryman
you are correct
had to go back to DONGFANG MOTORS to get the proper CDI
not many seem to know anything about this
Thanks
Old Aug 23, 2018 | 02:30 AM
Glad you got it working. Too many people assume all CDIs are the same, so you often get threads on here where the owner is being told, for example, "remove the kill wire and see if it runs", that only applies to one type of CDI.
badbowtie400
1) Engine problems..
Jul 14, 2013 07:43 PM
cphillips
Jun 27, 2013 07:58 PM
stand on it son
Apr 10, 2013 09:16 AM
skiipsquadracer
Dec 15, 2005 05:10 PM
