Kazuma 150 Dingo.
Old Nov 1, 2018 | 09:50 PM
flying sacha's Avatar
Default Kazuma 150 Dingo.
Hello, I bought a Kazuma 150 Dingo, it has been stopped for 2 years, and I have no idea where to start to make it work. I am new at this. I have only loaded it in my truck and the only information I have is that two years ago it has not been started and since that time, they did not touch it anymore !. Where to start?
Old Nov 2, 2018 | 03:40 AM
You will probably need a new battery. Change engine oil and check chain is tensioned correctly and in good condition. Lubricate it. Check the brakes work and are not sticking on, check pads for wear. See if it starts. If it doesn't spin over, you have some diagnostics to do on the starting side. If it does turn on the start button, but won't start, check for a spark at the plug, if there is one, clean the carb out and change the fuel for fresh.
Reelgator
Feb 12, 2019 04:41 PM
budd68
Aug 17, 2010 08:22 AM
DrFfreeze
Mar 26, 2007 11:16 AM
Prezzz
Sep 11, 2005 09:42 AM
