help no spark...
Old Apr 27, 2019 | 12:51 PM
Aaron Skinner's Avatar
Default help no spark...
Hi All...
ok ive brought my son a Apache 100cc quad bike ans it seems to have a spark issue..
When i got it i couldnt get a spark then i messed around with it and got a spark and got it running, then it just died after 30 mins, now no spark so i replaced spark plug, ignition coil, cdi, ignition switch, stator and regulator and got a spark again now its gone again?
Ive check the wiring to see if any loose connectors, cant start by electric start because the starter clutch is broken so can only kick start it and thats a pain as it sometimes slips ( needs new teeth on it)
the kill switch us 2 wires that are just loose no switch anymore as it broken and the other wires i think are for the lights and the electric start lever which is now broke
Im crap with electrics so not sure how to trace and test
also my new stator has 6 wires instead of 5 so i am unsure how to wire it, see pictures of mine the correct one and the other off ebay which they say to re-wire
any help with this guys?
f250
May 6, 2023 10:54 AM
Just My Luck!!!
1) Engine problems..
13
Jan 29, 2017 02:34 AM
Wildland
Feb 21, 2005 12:43 PM
