Baja 150 won't crank
Old Jul 26, 2019 | 02:20 PM
Arcbull's Avatar
Default Baja 150 won't crank
Hi,
I am trying to fix a Baja 150 quad for a friend that will not start correctly. It will start if the solenoid is jumped. I have found a bad spot in the safety switch wires coming from the hand brake while doing an ohm test I had no conductivity through the wires no matter if the brake was pressed or not until I held the brake down and wiggled the wires the it would sometimes show conductivity. I jumped the wires together but the quad wouldn't start. I started checking out the ignition switch and found that if I jumped power to the black wire on the back of the switch the brake light would work and the start button will then start the quad. I figured it was a bad ignition switch and purchased a new one installed it, but still no brake light and won't crank. Could someone give me some insight.
Old Jul 26, 2019 | 09:26 PM
Arcbull's Avatar
Originally Posted by Arcbull
Hi,
Nevermind I must have popped the fuse by the battery at some point the new switch fixed it.
jailhouse jackson
1) Engine problems..
Sep 14, 2017 04:27 PM
barchamb
Oct 29, 2007 10:48 PM
barchamb
Apr 6, 2007 04:42 PM
ScoobyDFW
Mar 16, 2007 03:09 PM
Uptmor250r
Oct 19, 2006 09:46 PM
