tao 125cc
Old Aug 9, 2020 | 10:23 AM
Manlythumbs's Avatar
Default tao 125cc
my sons 125cc quad will start and idle nicely. When you slowly bring up the Rpms its fine. When you give it a burst it stalls. I raised the idle speed and it seems a little better but still does it. I've closed the carb a bit and it is better. This issue started when I went from 87 octane to 93. Has anyone had issues like this.
Old Aug 10, 2020 | 02:30 AM
Most likely a partially blocked jet. When accelerating, an engine needs a slightly richer mixture (hence accelerator jets on more expensive carbs) so, if a jet is slightly blocked, the weak mixture will show up when the engine is accelerating.
Old Mar 25, 2021 | 08:23 PM
novastreetracer's Avatar
Sounds like fuel/air mixture is off. You can adjust it on screw.
Bobby Haddix
Sep 1, 2018 12:40 PM
Bamajoker
3) General Discussions..
Nov 15, 2016 10:22 PM
ryeguy1
1) Engine problems..
Jun 8, 2012 12:33 AM
andrewddrennon
Feb 7, 2011 07:58 PM
SCRAMIN
May 25, 2010 08:11 AM
