Atv won’t start
Old Jan 17, 2021 | 06:52 PM
Rem803's Avatar
Default Atv won’t start
I’ve read a lot of great answers on here. I hope someone has one for me. My Taotao 125 will crank but not start. Well a little history first. Was riding home and it just started losing power getting slower and slower. Turned it off when I got home and tried to start it and it ran for about 3 seconds and that’s the last time it started. Tried starting it at the plug since I do have fire. Used straight gas didn’t work starting fluid didn’t work carb cleaner still nothing. Adjusted valves also. Got a compression tester ordered but it feels like it’s got plenty of compression. What’s up????
Old Mar 25, 2021 | 08:18 PM
novastreetracer's Avatar
If you have spark and compression it is a fuel/carb issue. First you should check to make sure you are getting gas to carb. Pull fuel line to carb and turn gas on. Make sure fuel is running out of the line. If it is then would more than likely be a carb issue. Take carb off and clean it out real good and see if the helps.
Old Apr 19, 2021 | 09:30 PM
EDAWG's Avatar
I've heard of the Nut that holds the emissions return hose onto the air filter come off and fall into the intake preventing start. the nut inside the black plastic air filter that holds the assembly that connects the hose to the side of the air filter that is
Mistakes
1) Engine problems..
Jul 25, 2012 08:04 PM
BigBaller23
Jul 14, 2012 10:49 PM
quadcraz3d12
Oct 26, 2007 09:57 PM
daron
ATC 3-Wheelers
May 30, 2007 04:38 PM
