87 suzuki 185
Old Apr 28, 2012 | 12:38 PM
BigBaller23's Avatar
Default 87 suzuki 185
wont start when cold, we have good spark, great compression and great fuel, i have cleaned the carburator, changed the plug, and done everything i could think it might be, i spayed ether in the carb trying to get it to start it still did nothing. it will start if you pull it and pop it but it wont start when its cold. once it warms up it will start easily. got any ideas whats wrong?
Old Apr 28, 2012 | 06:28 PM
woodsidewarrior's Avatar
When you say great compression how do you know. Did you check it with a compression tester? It very well have low compression. Are the valves clearances in spec. With fuel, compression and spark at the right time it will start. It may not run well but should start. Is your plug wet with fuel after you try starting it?
Old Apr 28, 2012 | 07:24 PM
LT80's Avatar
LT80 Expert
In addition to the above post,
If it's electric start, it may not be spinning fast enough.
Old Jul 14, 2012 | 10:49 PM
fixingmybeast's Avatar
its probably your carb I have to turn up the idle when starting and adjust it back down once running.
VABrute
Jan 6, 2016 07:39 PM
clscott84
Sep 21, 2015 10:16 AM
merryman
Sep 19, 2015 03:15 AM
jsmit116
Sep 18, 2015 10:34 PM
Sep 1, 2015 11:59 PM
