CDI problem - wrong CDI?
Old May 13, 2021 | 06:19 AM
Carsten's Avatar
Default CDI problem - wrong CDI?
Hi,
I Got an Old 200 cc loncin with a broken CDI - No spark. I bought a new 6 pin ac recomended from the dealer. But it dosnt run well with the new one. Its hard to start, runs hard and sounds like it some times wanna go in the opposite direction when starting. When I borrow the CDI from my second machine it runs smoooth and nice. The dealer send a new CDI like the first (ac), but with the same result.
anybody knows what the problem is?
p.s. sorry for my english. Im danish
br Carsten
Old May 14, 2021 | 02:04 AM
Seems like the advance curve for the new CDI is wrong. They do not differ much as a rule, so your old Loncin must be unusual. I believe CDIs with adjustable advance curves are available, you may have to get one of those. Alternatively, if you can find what Honda engine yours is a copy of, and get the CDI for that Honda, it may work better.
Old May 14, 2021 | 02:15 AM
Carsten's Avatar
I Think You are right. Ill try that. Would be nicer though to be alle to order the correct one. But it seems all CDI ac look the same. Thanks for your input
Old May 14, 2021 | 01:35 PM
Carsten's Avatar
I now checked with an ignition gun. The new CDI is about 10 degres more advanced Than the Old CDI at idle speed. At higher revs the new dosnt advance at all. The Old one does.
so i need another CDI with the right advance. Has anyone experience with this?
extended300ex
Jan 11, 2013 11:01 PM
ILivSD
Nov 9, 2005 03:39 PM
wshrdskin
Jun 12, 2002 11:22 AM
