Think I have timing issues but not sure?
Old Oct 27, 2021 | 07:27 PM
CurtEdge's Avatar
Default Think I have timing issues but not sure?
Hey guys, so I recently decided I want to put a new head on my son's Tao 125, I got it pulled apart and went to install the new head when I noticed that the old head had the gear opposite from everyone on YouTube and also opposite of the new one I got.
I have the flywheel turned to the T marked with the line, piston is sitting perfect TDC but im wonder is the timing gear off by 180 degrees? How can I tell which position it should be in?
I guess what I need to know is when I'm at TDC and the rotation starts, the head should be just opening the intake valve, correct?
Also from anyone's experience do the Goofit pre-built heads on Amazon need valve adjustment? Or do they come pre adjusted?
This quad has been having trouble running since i bought it, could this timing issue be what's causing it or if it was 180 degrees out would it just not run?
sanchezjesusisawesome@gmail.com
Apr 10, 2020 11:19 PM
masonsdad
May 26, 2015 02:11 PM
rubbersalt
Apr 25, 2009 08:59 PM
stinckfinger
ATC 3-Wheelers
Dec 13, 2004 11:48 PM
snakeyes93
Jan 21, 2001 02:28 PM
