xTremeATV.com X-100 had Spark and now No Spark
Old Oct 3, 2022 | 05:01 PM
sixsims's Avatar
Default xTremeATV.com X-100 had Spark and now No Spark
Hi All,
New to the group and first time post. I pulled an x-100 (xtremeatv.com) out of about a 10 years storage the other day. It had spark and fired when I put a little fuel in the cylinder. Continued to have spark during troubleshooting, etc. but has lost fire now. I had connected a battery to the terminals of the atv battery and used it to turn the engine with the starter button. It spun fine but no spark.
Did connecting the battery do something? I'm guess voltage regulator or resistor of some sort?
I'm thinking I could replace the carburetor and correct this spark issue and it should run.
Thanks all,
Bobby
Old Oct 4, 2022 | 02:08 AM
Change the plug, then go through the "help diagnose stator" sticky at the top of this section. The most likely thing is a corroded connector after so long in storage, but the checks should enable you to narrow your search to one particular wire or coil. Don't take the readings listed there as gospel, different makes will have different readings, but an open circuit or no resistance where there should be some, indicates a fault. Worth striping the existing carb and seeing if it will clean out before getting a new one.
Blackarrow
1) Engine problems..
Apr 7, 2018 01:13 AM
dgracing318
Jul 16, 2009 04:22 PM
Joshwfl
Jun 19, 2006 10:55 PM
Powercat400
Nov 16, 2004 09:12 AM
