02 big rex
Old Nov 26, 2022 | 10:50 AM
Brien's Avatar
Default 02 big rex
Just got an 02 Chinese quad 250cc water cooled. Engine idles a little high but good. But when I throttle it it will bogg and die. Can't seem to find a choke control. Any ideas?
Old Nov 27, 2022 | 02:41 AM
See if you can find a choke. Check the outside of the carb, there may be a plunger on it, or an extra cable, if there is, follow that cable. It is possible that it has an electric auto choke, in which case it will have wires going to fairly high up on the side of the carb. If it still bogs when the engine is warm, try a new plug, if that doesn't fix it clean the carb out. Remove the float bowl and jets, blow through them and the passageways they came from, with compressed air. no altering mixture screws etc, assemble and see how it is then.
MJS69
Dec 16, 2014 08:59 AM
GPhillips
1) Engine problems..
Jan 21, 2011 11:40 AM
diodedude
Technical and How-To Articles
Oct 15, 2009 03:01 AM
Stewart
May 10, 2002 12:33 PM
