125cc TaoTao leaking carb
Old Jul 19, 2023 | 03:33 PM
Bobprivate's Avatar
Default 125cc TaoTao leaking carb
Leaking carburetor 125cc TaoTao. I could also use a photo of the hoses on the he carb. Any help appreciated. Was running fine and began leaking unexpectedly and leaked ever since it began. bobprivate1955@gmail.com
Old Jul 19, 2023 | 03:41 PM
djshad1469's Avatar
Float may be stuck. You can try tapping on it with a wrench some and it may free up. Might have to remove and clean it also.
Old Jul 20, 2023 | 02:35 AM
Turn fuel tap off. Run engine until float chamber is empty, then turn tap on again. If it is dirt stuck between float needle and seat, the rush of fuel past a wide open needle may dislodge it. If that doesn't work, remove float chamber and needle, clean and check it. The little spring loaded plunger can get to sticking, if it does, fit a new needle.
Old Jul 22, 2023 | 07:57 AM
Bobprivate's Avatar
Default Djshad reply
Thank you!
Old Jul 22, 2023 | 01:51 PM
Bobprivate's Avatar
Default Leaking carb
Thank you
Old Jul 22, 2023 | 02:01 PM
Bobprivate's Avatar
Default Leaking carb/ photos?
I had a fuel line only attached at one end. Maybe a vent? I also had a place on the carb to attach a hose so I attached the fuel line I mentioned to that place on the carb. Maybe hoses aren't attached right? Any help or photos of proper attached carb hoses? Thanks!
QUOTE=Bobprivate;3481511]Leaking carburetor 125cc TaoTao. I could also use a photo of the hoses on the he carb. Any help appreciated. Was running fine and began leaking unexpectedly and leaked ever since it began. bobprivate1955@gmail.com[/QUOTE]
Zackattack91
Dec 11, 2016 03:46 AM
GeraldB
1) Engine problems..
Jun 16, 2016 02:07 PM
rickbass
Oct 11, 2014 10:09 AM
Chris White
Jun 17, 2012 01:10 PM
