Starter chain sprocket
Old Jan 20, 2024 | 06:19 AM
typete01's Avatar
Default Starter chain sprocket
Hello,
I have what I believe is a 90cc Coolster, the piston was seized and very scored. I completely tore down the engine and cleaned everything up and put new seals in. There were a couple of things during reassembly that i questioned the location of but think I figured them out. After putting it all back together a new starter really struggled to turn the engine over. I checked timing multiple times and backed the valves way off but it still could not do it. I took the head, flywheel and starter chain sprocket back off and the engine moves very easily and smoothly by hand. When I put the starter chain sprocket back on the crankshaft it does not move smoothly, there is a drag. I notice what looks like a bushing in the sprocket bore that I can't get to move, should this be free to spin? I am wondering if this bushing is causing the drag or if I am missing a washer or something and the sprocket is dragging on the back cover plate. Or could the seal be incorrect and is too snug making it hard to spin?
Old Jan 20, 2024 | 09:18 AM
typete01's Avatar
Ok, so I feel a little silly, I was chasing something that probably was not really an issue. I was using small gauge jumper wires
to the battery and after reading another post on here once I hooked directly to the battery it really zings if over now. Now to figure out why I don't have spark with completely new wiring, stator etc.
bobbydcee
1) Engine problems..
Apr 9, 2020 09:53 PM
BcTonyC
Aug 1, 2018 01:58 AM
BruceDeuce
Feb 1, 2015 04:36 AM
keithert
May 15, 2011 03:37 PM
sunl90cc
Jul 16, 2009 01:31 PM
