2) Chassis problems.. If your quad runs but you have other problems.. post in here.
Searching for Hensim 50cc gas tank
Old Jun 10, 2014 | 09:06 AM
adrenalnjunky's Avatar
Default Searching for Hensim 50cc gas tank
Hello all - first post!
My brother in law was given a Hensim 50cc for my nephew. was told "everything is good just needs a battery and fuel line"
Yeah, riiiight.
anyway my dad has had it - new battery and there's still no electrical anywhere - gotta start troubleshooting that first, but he's also diagnosed some stress cracks in the fuel tank that were jb-welded by the prev owner.
while most online parts searches yield similar looking tanks in the $35-45 shipped range - I can hardly find anywhere that has an identical tank to what we've got and when I do they're $90-170. Notice the mounting ears on the top of the tank near the back - those seem to be specific to just this particular quad.
While ths model of replacement tank looks almost identical in shape and style - it has the 2 bolts protruding from the top and no mounting ears - which I'm told the bodywork mounts to.
anyone got any suggestions on where to find the correct tank without spending a small fortune?
Old Jun 10, 2014 | 02:10 PM
If you have screws that go into the brass molded in fittings on the old tank,why can't you just add a washer and nut on the new tank that has the studs? Or possible the studs can be removed ?
Old Jun 10, 2014 | 03:29 PM
I could likely cut off the studs, no problem - but the cheap tank doesn't have the mounting points further back where you see the gold threaded inserts. thos mounting points apparently are required for body cladding attachment - and I'm told they are required for everything to assemble. I'm going to put eyeballs on it this evening for the first time.
Old Jun 10, 2014 | 04:23 PM
Jaster94's Avatar
Hensim 50cc ATV Gas Tanks | Hensim Gas Tanks | Hensim Parts
Gas Tanks 50cc-125cc ATVs Parts
Old Jun 10, 2014 | 05:42 PM
Yeah - I've already seen all of those - none of them are the tank I'm looking for though.
Old Nov 19, 2014 | 11:42 PM
Kazumauser's Avatar
PCCmotors carries that tank.
ATV GAS FUEL TANK HINSEM CHINA 50CC 70CC 110CC GT05
Hope this helps.
ReconBayou
Oct 16, 2019 02:24 AM
wrencher82
Sep 30, 2015 04:27 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
