110cc engine oil drain plug?
Old Feb 16, 2011 | 11:44 AM
point29's Avatar
Default ATA-125a fluid question.
Hi I'm new here and had a couple of questions. I have just got for my kids a taotao ATA-125a and wanted to know if there is a water plug or clutch plug on these motors or is it just add oil and thats it. I got this used so no manual.
Old Feb 17, 2011 | 11:31 AM
OneTenCC's Avatar
Water plug? Your 125cc should be air cooled. There is no separate drain plug for the clutch cavity since the engine/trans share the same oil.
Joel
Old May 28, 2011 | 06:03 PM
pbgbottle's Avatar
thank you very much for posting that pic of the oil drain plug .
i too was curious on which plug to pull ,i am about to do my first oil change .
on it TAOTAO 125D do i need to use anything on the threads to keep the plug from falling out .it looks like it is glued in ??
thanks
Old May 28, 2011 | 07:32 PM
point29's Avatar
The only 2 plugs you should have to mess with is the bigger bolt plug for draining underneth and the oil dip stick plug were you fill on the 125 models. the little crome plugs on top of the crank case are for nothing they are a dry clutch motor on the 125A & D. I hope this helps.
Old May 28, 2011 | 08:52 PM
  #15
pbgbottle's Avatar
thanks i drained and filled . overfilled actually. how much do these things take .
i put 950ml in and it ended up comeing out the dipstick hole. I took about 250ml out.
so i am asuming i have about 700 ml in there does thast sound about right?
the dipstick reads at the top of the full marks but it is kind of hard to read .
I am pretty sure that it is full though , i'm gonna let it sit overnight and i'll check it again in the morning. i did start it up and run it for a couple of minutes to circulate everythnig
thanks
Old Aug 3, 2011 | 09:33 PM
  #16
stripe's Avatar
I have a related question. I have a 125cc Tao and today was our first oil change. By mistake, we unscrewed the wrong bolt (the smaller one) and a spring and some sort of piston came out with force and fell into the oil pan, along with a bit of oil. Now, the problem is, we don't know in which order to put them back in since everything came out too fast.
Is it: 1) piston 2) spring 3) bolt or 1) spring 2) piston 3) bolt?
also, is the bit oil that came out of this whole a problem or is it just part of the overall oil reservoir which we'll refill as part of the regular oil change (using the right bolt this time!)?
Originally Posted by OneTenCC
Old May 22, 2017 | 04:25 AM
  #17
Jesica McCullough's Avatar
momofboys
Default lost plastic tip
Can you help? Pulled wrong drain plug . Spring and everything popped out. Someone went behind me and put it back in wrong and lost the black plastic tip that Goes on the cam chain tensioner inside of the crankcase. How do I get it out?
Old Dec 22, 2018 | 08:41 PM
  #18
Richard Walker's Avatar
I did the same thing today. Did you ever figure out what to do? I just put the plug back in and my son has been riding it all day.
Old Oct 15, 2019 | 02:19 PM
  #19
andy1987's Avatar
Default 110cc plug issue
hi mate I've just done same thing and un done the wrong bolt to drain the oil. I've got all the bits still but dont know which way it went in.did u manage to suss yours ?and help on it would be appreciated.
Old Oct 15, 2019 | 02:22 PM
  #20
andy1987's Avatar
hi mate did u manage to sort which way it went back in? cheers
