110cc engine oil drain plug?
Old Oct 16, 2019 | 02:48 AM
  #21
Someone had the problem more recently see https://atvconnection.com/forums/1-e...-faux-pas.html they sorted it.
Old Sep 3, 2023 | 10:40 PM
  #22
Tyler077's Avatar
Originally Posted by point29
The only 2 plugs you should have to mess with is the bigger bolt plug for draining underneth and the oil dip stick plug were you fill on the 125 models. the little crome plugs on top of the crank case are for nothing they are a dry clutch motor on the 125A & D. I hope this helps.
what would happen if filled the top Crome plug with motor oil would it hurt the engine or would it just leak out and still work fine?
Dame0927
Oct 29, 2015 10:13 PM
WilliamBos
Sep 30, 2015 08:08 AM
DOAinNY
Jun 12, 2015 02:26 PM
DOAinNY
Jun 11, 2015 10:34 PM
kevbowe
Jun 1, 2015 01:17 AM
