ata125 D maintenance check-list
I bought my son a new ata 125 D for Christmas but the owners manuel wasn't very helpful with maintenance and other things that need to be maintained on his atv. Does anyone have a helpful list...also, there is another cap (not for oil), is this for transmission fluid? everytime I try to put anything in it it just runs out? I'm not mechanically inclined at all so any suggestions/lists would help.
Thanks,
Tonya
Thanks,
Tonya
I really don't know if the 125cc engine is just a slightly modified 110cc engine or not. Perhaps others can comment. Here is a link for a 110cc manual that covers a lot of routine maintenance:
http://www.cbxmanmotorcycles.com/Dow...ice-Manual.pdf
Check it out and see if it matches your engine. Even though the quad brand name is different, often the engines are all copies of the same design.
That "other cap" is probably an access port to allow a timing to to shine down onto the ignition timing marks. You're not supposed to put oil in there, though you have plenty of company with others who have done the same thing.
The transmission shares the same oil as the engine.
Another link to a different 110cc engine manual:
http://api.viglink.com/api/click?for..._110manual.pdf
Model: Tao Tao ATA-125D 107cc 5.5 Horsepower Air Cooled Four Stroke
Spark Plug: NGK C7HSA or Autolite 4194 gapped at .0028
Oil: Shell Rotella T 15w-40 (No Energy Conserving Oil)
Fuel: 93 Octane, Ethanol Free (if available)
Headlight #75 assembly (buyatvsonline.com)
Tail Light #62 (buyatvsonline.com)
Brake Fluid: DOT 3
Fuel Line: 3/16”
Replacement Rear Brake Pads: Part # 220-999005 (motopartsmax.com)
Replacement Tires: AMS Swamp Fox 16x8x7 ($32.99 +shipping) http://[URL="http://www.jpcycles.com/product/TV00980"]www.jpcycles.com/product/TV00980[/URL]
For Parts go to: www.motopartsmax.com/index.php/main_page/vehicle/vID/320//page/3
Maintenance to be Performed every SIX Months:
Fuel Capacity:
1.1 Gallons
Front Hand Brake:
Drum
Rear Foot Brake:
Hydraulic Disc
Tire Front:
16x8-7
Tire Rear:
16x8-7
Suspension Front(inch):
10.8
Suspension Rear(inch):
11
Battery:
12V/4Ah
G.W.(lbs):
253.02
N.W.(lbs):
206.82
Max Loading(lbs):
132
Overall Size(inch):
50x33.5x38
Seat Height(inch):
24.81
Ground Clearance(inch):
I have 2 ATA-125D atvs and this is the maintenance schedule I use.
Brake Fluid: DOT 3
Fuel Line: 3/16”
- Oil change (700 ml) Note: Warm engine for 5 min before draining.
- Spark Plug (NGK C7HSA)
- Replace Inline Fuel Filter (motopartsmax.com model #332-999001)
- Check /Clean Air Filter (35mm?? Model #340-999026)
- Clean Spark Arrestor
- Check Tire Pressure (10 psi)
- Clean and lube chain with chain oil.
- Tighten chain. (½ inch of play)
- Check brake fluid and replace once per year.
- Check all nuts and bolts for tightness. Apply blue LocTite.
- Adjust valves (.004 intake and exhaust) Done on COLD engine.
Fuel Capacity:
1.1 Gallons
Front Hand Brake:
Drum
Rear Foot Brake:
Hydraulic Disc
Tire Front:
16x8-7
Tire Rear:
16x8-7
10.8
11
Battery:
12V/4Ah
G.W.(lbs):
253.02
N.W.(lbs):
206.82
Max Loading(lbs):
132
Overall Size(inch):
50x33.5x38
Seat Height(inch):
24.81
3.54
braap123
Sep 7, 2015 12:58 PM
