GY6 250cc no spark please help???
Old Jul 31, 2011 | 08:21 AM
Ojoe86's Avatar
Exclamation GY6 250cc no spark please help???
Have a kart with the gy6 engine and it will not spark. I have burnt up 2 cdis so far and have no idea why! Thinkin it may be the harness but not sure. I have also read that the ac cdi and dc cdi look the same but will not work the same... Any tests to try? I have no idea what the cdi boxes were (ac or dc)
Old Jul 31, 2011 | 12:19 PM
LynnEdwards's Avatar
Electrical Expert
I don't think there are 250cc GY6 engines. Perhaps it is a 150cc engine?
How did you determine that your CDI is burn't up? If smoke and flames came out of it that is one thing, but if you replaced it and it ran for a while then died maybe somethng else is going on.
You are right about AC and DC CDI's looking the same but being compatible. Here is a generic procedure on how to test whether you have a DC CDI or an AC CDI:
The 2 plug 6 wire CDIs come in two different designs. One is powered off 12 volts DC, and the other is powered off a moderately high voltage AC which comes from the stator. Unfortunately there is no reliable way to tell the difference between the two by just looking at them. To be sure you need to use a meter to find out which you have:
1) Unplug the CDI, and turn on the ignition. Do not crank the starter motor. Use a meter to measure the *DC* voltage on the pin labeled "AC ignition power" in the wiring harness to both ground pins in the 4 pin CDI connector. If you measure 12 volts DC then you have a DC powered CDI.
2) If you don't measure 12 volts DC on the ignition power pin, then switch the meter over to measure AC volts on the 200 volt scale. While cranking the starter motor, measure the AC voltage on the "AC Ignition Power" pin to the the Ground pin. You should see 40 to 80 volts AC. If you measure AC voltage when the starter is turning then you have an AC powered CDI.
Using a meter is the only 100% reliable way to figure out if your CDI is AC or DC powered. But there are some clues you can use that are usually (but not always) correct:
A) DC CDIs tend to be a little larger than their AC powered counterpart. This is because the DC powered CDI needs a bunch more circuitry to convert the 12 volts DC to the moderately high voltage supply that all CDIs must have.
B) Most (but not all) DC powered quad ignition systems do not use the kill switch input pin. The CDI connector pin usually has no wire tied to it. AC powered quad ignition systems usually do use the kill switch input pin.
Where did you get your replacement CDI's? Were they AC or DC? On a lot of AC CDI designs, if you plug them into a DC wiring harness the CDI burns up instantly when you try to start the quad - often with a bang and shrapnel.
Old Jul 31, 2011 | 10:45 PM
Ojoe86's Avatar
Well 1st off, i orded them from ebay so yea thats the 1st prob and by burnt up i mean actually burnt a hole through the side of the cdi while cranking with smoke and all!!! I will find out what cdi i have 2marto evening.
Old Jul 31, 2011 | 10:48 PM
Ojoe86's Avatar
If this helps
http://gokartsusa.com/250kdunebuggy.aspx
Thats my exact kart
Old Jul 31, 2011 | 11:50 PM
Electrical Expert
Go ahead and do the tests, but I bet you find you have a DC powered CDI wiring harness, and you've been plugging in AC powered CDI's.
So what happened to your original CDI? If you plug it back in I expect you don't get smoke, right? Perhaps it is worth looking at this further with a meter (in case the CDI wasn't your original problem after all)?
I've ordered lots of stuff off ebay and have had good luck, but I know what questions to ask the seller. If I don't get an intelligent knowledgable answer I go to the next seller.
Old Jul 31, 2011 | 11:54 PM
Electrical Expert
If this helps
Kinroad Runmaster Phoenix 250 Dune Buggy
Thats my exact kart
A CN250 liquid cooled engine is not a GY6 engine. But no matter, both these engines use the same 6 pin CDI - which can be AC or DC powered .
Old Aug 1, 2011 | 10:31 AM
Ojoe86's Avatar
I bought the kart couple weeks ago for 400... Said had no spark and he had took the cdi somewhere and couldnt find it... So thats my starting point
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
