New to these chinese ATV's
Old Jan 2, 2013 | 03:48 PM
longrange1971's Avatar
Default New to these chinese ATV's
Hi folks,
I am new to the forum, however have utilized some of the great info on here regarding Chinese ATV's. I purchased a used 110 for my son and have been steadily working on it. I believe that it is manufactured by the Ba yun (Sp?) Group. I have finally got it running with the help of info on this board. I wanted to thank you guys for the help already. Luckily the guy I bought it from had two and has allowed me to use the other one for parts to get this one going. I may just buy the second one to keep for parts. Is there any hints you can give me to keep this thing going. My son is 8 and wanted to get him started on something reasonably in-expensive to start to make sure that his interest is there. Plan on upgrading him in a couple years if he continues to stick with it. Once again thanks for the help!!
Old Jan 2, 2013 | 09:29 PM
max1298's Avatar
Theyr are very finiky with adjusting but are good for what you pay for. All I would say is if your looking for a high usage reliable bike go for a main brand like yamaha, never go wrong, but for a fun little basher there okay
Old Jan 2, 2013 | 11:12 PM
Justjoe's Avatar
I'd replace the carb with a mikuni. That seems to be the biggest problem I've had with them, the carbs are junk
Old Jan 3, 2013 | 06:29 AM
Thanks guys,
Well I did have problems with the carb that came on it so I replaced it with a new one. It was not a mikuni. If I have problems again, I will go that route. But with the new carb on it she is now running like a brand new. Do you know if this brand bike charges the battery as it is running or do I have to keep the charger on it (I had it backwards in the first post, its made by Yun Ba Group). I do not have the plug that goes in the back, but I do put the alligator clips right to the battery. This thing also needs some work to the rear disc breaks. Thats this weekends project.
Old Jan 3, 2013 | 07:49 AM
max1298's Avatar
Normally the A/C generator inside the crankcase should be putting out some voltage then going into reg/rectifier where in converts it into about 13/14v D/C which should charge your battery, if you measure your battery terminals with a multimeter and you should get 13/14v, but if your bike is like mine it doesn't . If not just put it on a trickle charge every now and then
Old Jan 3, 2013 | 10:33 AM
Ok great, I will check that. Thanks for the help.
Old Jan 3, 2013 | 11:10 AM
max1298's Avatar
No worries mate
Old Jan 16, 2013 | 03:40 PM
willyoo52's Avatar
Hello I am new and I was wonder how does these Chinese quads handle in the mud and water I am thinking about buying one for my 10 year old?
Old Jan 23, 2013 | 08:10 AM
H. Thompson's Avatar
Working on grandsons dino 50cc. I need some missing and broken parts. Cant seem to find a sight for parts. Joined this forum hoping somebody on here could maybe help this deparate grandpa, thk you
Old Jan 23, 2013 | 10:36 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Is there another name other than Dino? (brand name)
