2007 hensim 110cc
Old Feb 17, 2015 | 09:14 AM
alix's Avatar
Originally Posted by whygostockcom
Does the brake light light up when you use the brake? If not it is the micro switch on the brake.
thanks for advice but don't have the wire for tail light ...is there another way of testing if this switch is working right??
Old Feb 17, 2015 | 09:16 AM
alix's Avatar
Originally Posted by mywifesquad
Pour some fuel in the spark plug hole.. put in the plug, attach the plug wire and crank it over.. What does it do?
It sounds very dead in the video.. I would check valve clearances nextr.
thanks for advice will try this later when get home .....I don't have a thickness gauge to measure the clearance of the valves is there any other way of testing this ? thanks
Old Feb 17, 2015 | 08:15 PM
whygostockcom's Avatar
Banned
Tappet Feeler Gauge, .002-.003 inch (.05-.08mm) - Whygostock.com
You cannot test it accurately without a feeler gauge.
Old Feb 19, 2015 | 10:38 AM
alix's Avatar
thanks for help!! the bike is now running again but when start it jst revs its self ...also the start button dosnt work on handle bars :/
Old Feb 19, 2015 | 09:43 PM
  #15
Banned
Sounds like the throttle cable is too tight. Or the carb slide is being held up by the idle screw or contaminates. Hensim is long gone. Wouldn't worry about the start button. Just jump the relay or build your own start button. Just not worth taking to a shop and having a custom start button built. Sell it and buy a Taotao.
Old Feb 20, 2015 | 03:58 AM
  #16
"Hensim is long gone" Maybe, but parts for it are not Hensim ATVs Parts
Old Feb 21, 2015 | 01:34 PM
  #17
alix's Avatar
thanks vmuch for help I put new pistions and seals in today and brake working perfect also put a air breader on to the carb from another bike and it now running perfect again thanks !! stat button still no working but gona join a door bell or something to the relay and have door bell button up at handle bars thanks!!
Old Mar 7, 2015 | 04:35 AM
  #18
alix's Avatar
have being trying to figure out y start buttons not work I disconnected the kill switch wier from the cdi (white/black wier) when I hit start button still nothing happens , it will start right up when jump turminal on relay .. what does this mean ? I'm guessing.g its either the relay or start switch itself the o my thing that's working on the left handle bar is the kill switch when its attached to cdi ,the lights and starter arnt Woking ...have being using quad just by jumping relay starts no bother
Old Mar 7, 2015 | 12:44 PM
  #19
Banned
Whygostock offers starter relays for about $6.
Old Mar 7, 2015 | 03:43 PM
  #20
alix's Avatar
thanks for reply would like to find out if the switch is the issue or relay before buying parts
