Reg Wheels bearings to match
Old Jul 2, 2022 | 10:23 AM
jerry fathi canada's Avatar
Default Reg Wheels bearings to match
Greetings . I wanted to know between you my friends and the members of the group. Has anyone changed the bearings of the rear wheels of the Odes 400 ATV, and if so, which of the other ATVs are the same size as the one you purchased ? Is your ATV Odes Independent Excel or not ? or only 1 piece? Yesterday I was preparing ATVs for the outdoor season. I saw that the rear wheel of my children has a little play not too much , because last year I changed all the front and rear bushings. I think The only problem is the bearings, if anyone can help, I would be very grateful
Old Jul 3, 2022 | 02:28 AM
Most bearings have the sizes stamped on the inner or outer race. Failing that, an accurate measurement of inside dia, outside dia and width, should enable any local bearing supplier to match the bearings. Same goes for oil seals. Inside dia of seals is more accurately measured by checking the size of shaft that runs in it. Take the old ones to the local "engineers supplier" and they will match them.
Old Jul 3, 2022 | 01:43 PM
I relay appropriated . you are always helpful and your advise is right on . only thing i was worried to take it out and cant find in my area . but i heard it is shop they have all size . also surprise me . my kids Odes is very low Km may be 400 km and others 600 km . and 2 years ago i change all brake pads also all bushing . yesterday i was going to make it ready for season and when i move the wheels .
I saw that both rear wheels play a little Wobbling . i said all bushing is abstrusely new . only thing can be wrong with wobbling is wheel Bering . anyway i really appropriated for your help
sincerely
Jerry Fathi
Old Jul 4, 2022 | 02:07 AM
Take a very close look at the hubs when you wiggle those wheels. I usually shine a light on them when doing it as you can see where the play is, bearings or bushes, or just a loose bolt. A tiny bit of play at the hub shows up as quite a lot of movement at the outside of tyres. I find polybushed suspensions can wear rapidly. I fitted a 400 King Quad front lower A arm with polybushes two years ago, originals were rubber. Came to service it last month and the polybushes were well shot, top A arms still had original rubber bushes and were still fine.
sport700man
May 29, 2009 07:21 AM
SPORTSMAN70003
Jun 12, 2005 04:36 PM
Krank
Dec 10, 2004 01:00 PM
accorracer
Jun 20, 2003 01:41 PM
