500 Rear Wheel bearings
Try www.radmfg.com. They sell a billett rear axle carrier with bearings and seals for $219.00. Finally some performance parts for the rear axle.
Steve Lubecki
Steve Lubecki
Thanks for the reply guys,,i was hoping for an NTN or an SKF number so that I could get the bearings before I had to take one out to find the size. I am going to take my quad to work and drill and tap ALL the bushings in the front and rear for grease nipples. I took the back end apart to change a CV boot and found more than just the bushings were worn. [img]i/expressions/face-icon-small-sad.gif[/img] So just beware, I have 3000 miles on mine and already I wish that Polaris hadn't removed the grease nipples. Anyway,, if I can get a number, that would save me the hassle of removing the bearing, taking it in to get the correct one, putting it back in, and then going to work to take it out again,, I hope you see where I'm coming from.
Hi.
I believe these are the numbers. They are timken numbers and are one of the best bearings out there. you will need 2} L-68111 cups and 2} L-68149 cones. The seals are CR #18558 but try and get national seals because they are better. You should be able to get these from any bearing wharehouse in any cit they are pretty common. I amd going to try and make the rear axle oil bath when I get a chance I think that would work better.
Rick
Rick
