Help Identify broken part
Old Feb 24, 2023 | 04:37 PM
Joe31329's Avatar
Default Help Identify broken part
Can anyone help me identify what is broken and where to buy a replacement?
Old Feb 24, 2023 | 10:07 PM
nny's Avatar
nny
Ill ask the obvious question whats the year make and model of this unfortunate atv?
Old Feb 25, 2023 | 01:56 AM
Can't tell because the dirt on it, but is there a hole in that lower swivel/cross tree, that the bolt in the middle of the king pin screws into? If so, I would guess all you are missing is a spacer which would go between king pin and lower swivel. Clean it up and take a picture of the other side's king pin assembly, which should show what is missing. Also answer nny's question.
Old Feb 25, 2023 | 06:27 AM
djshad1469's Avatar
​​​​​​Pretty sure this is it. Had on go on me last summer. Available at vmcchineseparts.com
Old Feb 26, 2023 | 02:42 AM
Absolutely certain it isn't. That "tab" has the swivel tube built in. On the OPs pic the swivel tube is in the A Arm. If they had cleaned it before the photo you could tell, but I would guess there won't be anything wrong with it anyway, just lost the lower spacer and nut, if it isn't a captive nut.
Old Feb 27, 2023 | 06:54 AM
Coolster125's Avatar
ChineseAtvOwner
It's the spindle and spindle bracket all your missing is the nut that holds the bolt in place
Codygraham123
Nov 16, 2022 08:04 PM
Daverr
May 10, 2020 04:59 AM
Drew Cormie
ATC 3-Wheelers
Oct 8, 2017 09:31 AM
jason_larrow@msn.com
Jul 30, 2017 01:34 PM
Daviddls12
Oct 30, 2015 05:34 PM
