Drain Plug fell out!!!
Old May 16, 2003 | 06:07 PM
yellowexracer's Avatar
Default Drain Plug fell out!!!
I was riddin today and I felt something on my foot so I looked down to see the oil shooting out of the drain hole cuz the bolt fell out. Good thing I found it. I must not have tightened it enough last night when I changed the oil[img]i/expressions/face-icon-small-blush.gif[/img]. Has anyone ever had this happen before?
Old May 16, 2003 | 11:32 PM
Coyotechaser's Avatar
Did you find the bolt and washer? If nothing was hurt then I guess it's better to have it too loose rather than too tight and stripped. How did you get it home?
Old May 17, 2003 | 12:55 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
When I bought my Rancher, the dealer filled it with oil, but didn't put the cap on. I didn't notice it until I hit 3rd gear and the hot oil went spraying out all over my leg.
Old May 17, 2003 | 12:28 PM
reconranger, The dealer was lucky you didn't sue them for burns to the leg. Like the people that sue because their coffee was too hot when they spilled it on themselves. Also the people that sue fast food places because the food made them fat.
Old May 17, 2003 | 08:28 PM
macgiver's Avatar
nope never have done that. i have done a lot of dumb things but never that.
Old May 17, 2003 | 10:17 PM
Sm0k3d's Avatar
My neihbor has an 86' 250r 3-wheeler and got his entire motor rebuilt. Took it out and the shop forgot to tighten the drain plug, emptied all the oil and blew his motor. Shop replaced the parts for free =X
Old May 17, 2003 | 11:03 PM
dzzy's Avatar
I did this only once, back in about 86, on a trx125. It was a regular and good customer at the place I worked at, and it scored his piston. I had to rebuild it for him but the humble pie I ate was the worst part. Ever since then, I have been paranoid about doing the same so I double check every drain plug (and any other crucial parts). It must work cause it hasn't happened since.
Old May 18, 2003 | 12:52 AM
Specta's Avatar
I replace the drain-plug gasket eveytime I change the oil. When you tighten the drain plug with a new gasket, being soft aluminum, as you tighten the plug you can feal the gasket "squish" and then the plug tighten up. Torqued perfectly and will never leak or come out.
Glad it didn't cost you an engine.
Old May 18, 2003 | 09:38 AM
dzzy's Avatar
Darn good point specta, I do too. It protects the threads in the cases against overtorquing too.
SDR-II
Sep 29, 2015 01:06 AM
Polaris5
Aug 29, 2015 09:11 PM
JohnnySplat
Aug 6, 2015 12:07 PM
momma's bike
Aug 6, 2015 09:49 AM
Shifts
Jul 3, 2015 07:59 AM
