adjustible shocks
Old May 19, 2003 | 12:41 AM
kp5791's Avatar
Default adjustible shocks
I HAVE A 2003 400I 4X4 AND I AM HAVING TROUBLE ADJUSTING THE SHOCKS. WHAT IS THE BEST WAY TO DO THIS?
Old May 19, 2003 | 11:24 AM
ttaylor's Avatar
Release the pressure off the springs by lifting the quad off the ground. Take the spanner wrench and place it on the adjusting collar and pull very hard. You may even try a little WD40 to clean out around and underneath the adjustment notches.
Old May 19, 2003 | 11:31 AM
TheGreenSubmarine's Avatar
I adjusted mine up and didnt like it at all, Moved it back down to lowest setting, and still wish it was softer.
Old May 19, 2003 | 09:43 PM
mudblaster's Avatar
i have mine set on the 2nd stiffest but i weigh 215lbs too,it might ride a little stiff but it also pushes the tires down more giveing you better traction when in the mud or when your climbing a hill and you need all the power to the ground that you can get. i found it a little stiff at first but now i love it because it dosent seem to roll in the corners as much and i find it handles better also. if i were you i would go to the local ride area and try them on each setting and see whats best for you give each setting ten or fifteen mins each you'll figure it out.
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
