how to lift my 650 ?
Old May 20, 2003 | 07:48 PM
trailride's Avatar
Default how to lift my 650 ?
I was woundering if anyone here has lifted there 650 and what you used and where you got the stuff? i know that they make a 2" lift kit for it but maybe someone here has done it with steel or other objects.I would love to know how ya did it and if it helped your groung clearance or not .
Old May 20, 2003 | 08:33 PM
bfb750BF's Avatar
I had a High-Lifter lift kit installed on my 1st Prairie 650 for a short time & it is a well made kit, heavy duty & not too hard too install. You will need to remove the front body plastic to install the front lifts & on the rear kit, you may need the help of some WD40 or light grease to help the rear lift block to slide into the mount. You will get more ground clearance from the front to the rear,except for the rear axle.
QuadRiders
Oct 22, 2015 04:13 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
