valve adustment
Old May 22, 2003 | 06:35 AM
Nickli's Avatar
Default valve adustment
I had a top end put on my 2000 400EX and Im wondering how often teh vavles should be re-adjusted. I have a trailtech computer so I can keep track of both hours and miles ridden. The reason Im asking is that I did my first oil change after the top end was done and when I re-started the motor, I heard a slight ticking that I didnt hear before I changed the oil. I also, went to the Honda oil. I think the shop tht did the top end used a different oil than the honda oil so Im wondering if that may have something to do with the ticking also.
Old May 22, 2003 | 10:15 AM
dzzy's Avatar
Under normal circumstance you don't need to adjust valve lash very often. If you want an exact figure, look in the maintainance schedule in the shop manual, or it may be in the owner's manual too. A "slight ticking noise" in a 400ex isn't considered out of norm, or it could indicate a need to inspect the lash. I have a hard time buying that the brand of oil makes much difference in terms of engine noise. Are you sure it wasn't there before? Make sure you follow the procedures EXACTLY in your owner's man or shop manual for checking the oil, or you will have the wrong amount.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
