Ron woods clutch springs?
Old May 22, 2003 | 10:16 PM
1BigDSRider's Avatar
Default Ron woods clutch springs?
Anyone running the ron woods generation 3 clutch springs. Do you feel they are any better. How much stiffer is the clutch lever?
Old May 22, 2003 | 10:40 PM
buttfungus's Avatar
I have the 60% springs and they are alot stiffer than stock. Similar to the TVI springs. They work great!
Old May 23, 2003 | 02:07 AM
Thanks for the reply buttfungus. Going to order them monday for Atpt nationals.
Old May 23, 2003 | 10:32 AM
MrMeaner's Avatar
Dont waste your money on the 40% springs. The 60% are the way to go. It will make the clutch harder but they dont slip. Ill sacrifice it. You can try an easy pull clutch lever I heard they are good.
Old May 23, 2003 | 10:41 AM
buttfungus's Avatar
Yeah, Mrmeaner is right on! The 60% springs took a little bit to get used to, but man do they make a huge difference!
Old May 23, 2003 | 11:17 AM
JEFFROE's Avatar
i had them on my stage III kit and they worked great. when i went to the 760 i needed a stiffer set.
Old May 26, 2003 | 12:02 AM
PUSHINTHELIMIT's Avatar
I also just got the ron wood 60% springs and I love them! I don't mind the harder clutch pull, because I know mine wont ever slip again. [img]i/expressions/face-icon-small-wink.gif[/img]
Old May 27, 2003 | 02:48 PM
ScoobyDFW's Avatar
I have PAMI clutch springs. I need a stiffer set. Where can I get them? My 9 disc barnett carbon fiber clutch is smoked after 3 rides, using non-synthetic oil.
Old May 27, 2003 | 03:02 PM
biggerisbetter's Avatar
Scooby, If thier ever was anyboby that NEEDS a "Clutch lockout system" it is you!! Your quad has SO much torque/HP, I dont think you will ever have much luck with any clutch/spring combo. I saw your bike finally hook up before your clutches went, and I didnt think it would be possible for you to STAND-UP your quad with that +8[img]i/expressions/face-icon-small-shocked.gif[/img]
When I talked to that guy at "lockout" he said he had a friend that has a DS, that was pushing him to develope a lockout system for it, but needed some more #'s to make his R&D worth while, maybe you can give him a call.
GOOD LUCK
Bigger.
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
