Rincon brake/tail light problem
Old May 24, 2003 | 08:24 PM
1fitman's Avatar
Default Rincon brake/tail light problem
I would have never noticed if my bud riding behind me hadn't noticed it. My brake/tail light stays on all the time. As soon as I turn the key the tail lights come on, I have the head lights off. I've checked for loose wires and everyting seems to be in place, Anyone have any ideas this is driving me crazy!!! plz anyone
Old May 24, 2003 | 09:02 PM
Blaster200FMF's Avatar
I had a Honda recon that did the same thing , dealer said the brakes were sticking lightly, check thoses first if that is not the problem check to see if you have a short anywhere, hope this helps you.
Old May 24, 2003 | 09:45 PM
650T's Avatar
You need to adjust your back brake light adjustment it is to tight.Read your manual it will tell you how to do it.
My Rincon
Old May 24, 2003 | 11:32 PM
1fitman's Avatar
I backed out the rear brake lever adjusting nut, and still a no go, think it could be the front brakes. Was going to adjust those but getting late maybe try that in the morning. Tnx for the replies guys.
Old May 25, 2003 | 02:53 AM
gergb's Avatar
Pretty dumb dealer if you ask me,(I sure wouldn't let him work on my quad)... Honda Recons don't have "Brake Lights"!! Only a tail light.
Old May 25, 2003 | 07:41 AM
dzzy's Avatar
I saw one rincon with the same deal, and the problem was the rubber boot for one of the front levers was caught in between the lever and one of the front brake light switches, depressing the small tab on it. Also it could be a faulty switch on any lever. Unplug them one by one and see which one makes the light go out. Or bring it to the dealer and let them deal with it as you are under warranty anyway.
Old May 25, 2003 | 09:49 AM
goattrotter's Avatar
Push the rear brake handle to see if it is pushing the switch back , you will here a click if the handle is not coming all the way back.
Mark
Old May 25, 2003 | 02:13 PM
1fitman's Avatar
Thanks for the replies guys, the rubber boot isn't in the way and the brake light switch clicks when the brakes are applied. I unplugged the front brake switch and the lights stayed on, was gonna unplug the rear brake switch but looks like you'll have to remove some other stuff before you can get it unhooked. I'm hoping it's the switch on the rear brake lever. Guess it's back to the dealer, gah I just hate hauling it all the way back to the dealer. Thanks again guys for the input.
skinnyr6
Aug 25, 2023 02:18 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
