how do you wash your polaris?
Old May 25, 2003 | 09:23 PM
kblazk's Avatar
Default how do you wash your polaris?
I can't get the dirt off with a garden hose so i use a pressure washer, I don't hold it in one place to long cause i don't want to mess it up, anyone else use a pressure washer??? And how do you keep dirt from collecting all the time on it?
Old May 25, 2003 | 09:31 PM
2manytoys's Avatar
I use a hose with a high pressure knozzel. When it is clean and dry I use wd-40 or some type of shine spray on all matel surfaces and wax the plastics with plastic wax. The wd-40 helps the best. It will be much easier to clean after wards.
Old May 25, 2003 | 10:12 PM
TB400's Avatar
do what 2manytoys says and aftert that lubricate your chain definaltly
Old May 25, 2003 | 10:51 PM
kblazk's Avatar
yeah my frame seams to have a lot of water spots on my sportsman 500, so should i soak the frame in wd40? Or should i soak it in son-of -a-gun? Should i put anything on the engine? Also around the decals there seams to be grime colleting that is really noticible on the yellow plastic.
Old May 25, 2003 | 11:08 PM
dcatt's Avatar
I use a pressure washer that I bought at Wal-Mart, (less than $100) it isn't very powerful and I don't hold it on any critical areas like tie rods, suspension, or balljoints for any extended time. I think that the flat spray from the nozzle is what knocks the dirt off. I wax the plastic about every other ride which may seem like a lot but it seem to keep it looking better.
I also spray wd-40 on the underside of the fenders, engine,hoses and frame and that seems to make the mud come off easier. I have heard of people using Pam non-stick cooking spray also to ease the cleaning process, which makes sense I guess. I also use a product called Meguire's 5 minute detailer on the plastic instead of wax from time to time, it also works good on your helmet, just spray it on and buff it off.[img]i/expressions/face-icon-small-cool.gif[/img]
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
WilliamBos
Jul 25, 2015 02:41 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
