1996 Sport 400L - HELP NEEDED!
Old May 26, 2003 | 09:28 AM
RAZOR217's Avatar
Default 1996 Sport 400L - HELP NEEDED!
I'm trying to remove the drive clutch and I'm having problems. I've removed the retaining bolt. I'm using a loaclly made drive clutch puller which threads into the clutch body and pushes againts the engine out put shaft. It looks as if the clutch has moved a 1/2 inch but is bound up. It looks pretty straing forward and it should just come off. AM I missing something here?
Old May 26, 2003 | 09:38 AM
ftwflh's Avatar
can you post a pic of your homemade puller? Try driving the pulley back on and try it again.
Old May 26, 2003 | 10:44 AM
CED's Avatar
CED
Try tapping on the end of the puller with a hammer.If it moved a 1/2 an inch it should come off.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
quadnob
May 29, 2015 07:25 PM
pancake
Oct 21, 1999 10:43 PM
rweissen
Oct 11, 1999 01:48 PM
RidE
Aug 6, 1999 02:34 PM
