DS spraying anti freeze
Old May 26, 2003 | 03:23 PM
BigWaynester's Avatar
Default DS spraying anti freeze
I was riding the ds a few days ago, after about an hour, antifreeze started spraying out. I did not see where it was coming from, just noticed it on the side of the quad, the next day after washing it, I opened the cap, and it still had a little pressure, so I know the radiator is not leaking, then I filled up the radiator, let it run for a while, rode it around the yard a few times, no leaks, so I took it for a ride, and then after about an hour, I noticed I had antifreeze sprayed on the side again...It appears to be coming out of the reservoir cap vent..Now the other day the reservoir was full when it sprayed out..this time it was half full when it came out..Any Ideas?
[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 26, 2003 | 03:33 PM
Also, I did not notice the fan coming on, maybe overheating? The red light did not come on.
Old May 26, 2003 | 03:45 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
possible blown head gaskit.. check to see if your oil has any anti-freeze also. mine did the same thing when i blew a head gaskit. what mods do you have? maybe try to re-torque the head
Old May 26, 2003 | 04:49 PM
14mins's Avatar
Blown headgasket
Old May 26, 2003 | 05:08 PM
Hightower's Avatar
dam wayne, that sucks - sounds like the head gasket to me too. the gasket can be leaking only under the pressure of compression, allowing motor compression to force antifreeze out of the tube, and not necesarily show up any coolant in the oil. you need to have a reputable mechanic perform a leak-down test, not just a quick compression check. if he knows what he's doing, he'll know what a leak-down test is, and will be able to tell you exactly what's up.
dude, that blows big time, no pun intended. I was hoping you would be coming out west with us...[img]i/expressions/face-icon-small-sad.gif[/img]
Old May 26, 2003 | 07:05 PM
dsracer666's Avatar
mine did that the other day it was so hot I could hear the antifreeze boiling in side!
Old May 26, 2003 | 07:07 PM
jeffnrivercity's Avatar
It does sound like the head gasket [img]i/expressions/face-icon-small-sad.gif[/img]
The good news is that Team-Pami now has new and improved head gaskets for the 703 and 760 that are alot better then the old ones [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-smile.gif[/img]
Jeff
Old May 26, 2003 | 07:22 PM
Jeff
This don't sound good[img]i/expressions/face-icon-small-sad.gif[/img] but what else could it be ? It takes about an hour of riding before this happens...Jeff, do I need to get one from gottfried, or does someone here in the states have them.?
Old May 26, 2003 | 07:44 PM
I am not sure if anybody in the states is carring them yet???
Best bet is to email Gottfried.....
Jeff
Old May 26, 2003 | 08:11 PM
Jeffnrivercity, are the new pami head gaskets the aluminum tripple layer with rolled lip groove for o-ring? just wondering because that is the one i tried and it seemed to hold up for about 1 hour, but then the bottom end went out. but the head seemed to remain sealed with this gasket.
