anyone conquor choke cherry hill on a quadracer ?
Old May 26, 2003 | 11:46 PM
HUEDOGG's Avatar
Default anyone conquor choke cherry hill on a quadracer ?
i have been watching these ''wyoduners'' videos and some raptors and DS's couldnt make it up the hill so i was wondering if anyone took their quadracers up it.
Old May 27, 2003 | 12:05 AM
Lateralus's Avatar
A friend of mine last year made it up on a Suzuki LT 250.Sand was sorta wet though.
late,zubbeyboy
Old May 27, 2003 | 12:20 AM
Sandgod's Avatar
If 250r's can get up a Quadracer will. Most R's are are built up so it's hard to know what's inside unless you ask.. He has a stock Dale going up so I will try on Independence Day. I will be w/ Wyoduner and others.. I'm gonna run 8 paddle Sand Devils, then try 6 paddle Gliders, then an 8 paddle Hauler/Glider combo.. Maybe my brother will try the same on his Z400 to see which is the best tire..
Old May 27, 2003 | 12:02 PM
HUEDOGG's Avatar
you think a quadracer withFMF pipe,coolhead,k&nfilter,vforce reeds,wiseco boost-ported piston,bored .080 over,and18 inch paddles would make it up that choke cherry.
Old May 27, 2003 | 01:13 PM
Duneaddict's Avatar
Mine climbs it in 3rd gear!
Old May 27, 2003 | 01:39 PM
ShadyRascal's Avatar
My 87 LT250R climbs it. Wiseco, 39 PWK, reeds, K&N, crappy pipe, Skate II's, stock gearing. I am in 2nd gear by 1/2 to 2/3 the way up, and from there it's a slow pathetic climb wound out. Darn near cooks the motor. I can do this in soft sand. I weigh 200. So technically yes, it can climb it, but you don't want your friends to see. [img]i/expressions/face-icon-small-frown.gif[/img]
Old May 27, 2003 | 01:46 PM
This brings an interesting point on weight also. Sunday we were at Devil's dune, tougher than choke cherry, and my friend's Raptor '02 stock would climb it. He's a skinny 16 year old, maybe 150 soaking wet. My '01 with K&N, geared down, me at the aforementioned 200 lbs sinewy lean muscle [img]i/expressions/face-icon-small-wink.gif[/img] I could get maybe 3/4 if you were real optomistic, maybe it was more like 2/3. Weight is everything in sand. The kid would be in first, and it would still pull uphill although a bit sideways. When I shift down to first, man it's all over. Turn and point down.
Old May 28, 2003 | 11:54 AM
HUEDOGG's Avatar
i weigh 130 and my 87 quadracer 265 will have a slight port job with polished ports and a new LRD pipe,k&n filter,v-force reeds,coolhead,11 tooth ,bored over again b/c i fried a piston when i blew a gasket. ill put another boost-ported piston in.think ill make it up devils dune?
Old May 28, 2003 | 12:26 PM
Wouldn't be too surprised if you could given your weight. Hopefully about 10 of your 130 pounds is all nards. Been there a bunch of times, and still, when you are sitting there looking straight at it, it makes your sphincter contract. One big, huge, steep, intimidating vertical wall of sand. With the run-up to it which goes down thru the bowl, I hit it at top speed on the Raptor, I mean 5th wound out. Pretty wild stuff. If I could only get a picture to do it justice.
dannytas
Sep 26, 2017 06:31 PM
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
