Reeds for Blaster
Old May 5, 2000 | 03:35 AM
Baloo's Avatar
Just want to find out what the performance will do on my bike if I put in Booysen Reed valves, change the jet and change the front sproket from a 13 to a 15.
'96 Blaster
Old May 5, 2000 | 11:02 AM
hittinhard's Avatar
I dont think you can fit a 15 tooth sprocket on the front. Using a 14 it required a little work to the side case.
I've heard just adding boyseen reeds helps out. I just jumped straight to the rad valve.
Old May 5, 2000 | 12:44 PM
Ssabbot's Avatar
you cant put on a 15 tooth and befor you go to a 14 tooth you will want to get a new pipe and intake manifold with a boost bottle for more low end. or you probably wont be happy with it. aftre that if you want a little more top speed go with some 21in rear tires.id go with the ram valve also.
QuadRiders
Oct 22, 2015 04:13 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
