SuperTrapp IDS2 Help.....
Old May 28, 2003 | 10:36 AM
HareScrambleRacer's Avatar
Default SuperTrapp IDS2 Help.....
I've got my carb dialed-in for the (10) discs I currently have in my exhaust, but I am wondering what changes (if any) I would have to make if I installed 1 or 2 more discs?? Would 1 or 2 more discs make enough of a change to cause a main jet change or a neddle shim?? Would 1 or 2 more discs even make a noticable performance improvement?? I am currently running a 135 main with a neddle shim. I am running a Twin Air air filter with the stock air box. Any suggestions would be appreciated!!
Old May 28, 2003 | 12:45 PM
stebob's Avatar
I'm assuming this is for the Lakota. You more than likely not notice any difference by adding any more disks once you've installed 10. I don't notice anything on mine with additional disks after 10 are put in.
Old May 28, 2003 | 12:48 PM
Sorry...I forgot to add that this is for the Mojave.
Old May 28, 2003 | 04:07 PM
mojaveaddict's Avatar
If it has a quiet core then adding more than the ten will do nothing because the core has reached its max flow by ten disc. If it is a race core adding more disc will make it flow more. Adding two more disc will probably not require a jet change unless you are already borderline on being too lean.
Ramimac
May 10, 2001 02:35 AM
mojaveadict
Apr 22, 2001 09:39 PM
wheeliedude
8
Mar 27, 2001 02:21 PM
cdk
Mar 16, 2001 12:59 PM
ReconBoy
Mar 14, 2001 10:51 AM
