300ex crank in 250x?
Old Jun 3, 2003 | 06:28 PM
precisionautomachine's Avatar
Default 300ex crank in 250x?
Will a 300EX crank work in a 250X case?Will I need the 300EX ballace shaft or are they the same?Anyone have any info.Thanks in anvance!!
Old Jun 4, 2003 | 09:38 PM
WISTECH's Avatar
The 300ex crank has different flywheel to make room for the starter clutch. It also has a longer stroke so you would have to use a 300ex rod and piston . I think you could get away with the same balancer but I am not sure. Did your bearings go out? If they did be sure the right case cover seal that feeds the crank is not damaged. Call powroll for the details.
pgamboa
Dec 24, 2023 11:52 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
QuadRiders
Oct 22, 2015 04:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
