300ex crank in 250x?
The 300ex crank has different flywheel to make room for the starter clutch. It also has a longer stroke so you would have to use a 300ex rod and piston . I think you could get away with the same balancer but I am not sure. Did your bearings go out? If they did be sure the right case cover seal that feeds the crank is not damaged. Call powroll for the details.
