I am new with ATVs, help please?
Old Jun 4, 2003 | 10:50 PM
MrMan15's Avatar
Default I am new with ATVs, help please?
Ok.....I am extremley new when it comes to ATVs. I just got a Yamaha Raptor (660, 2001) and I need some help. It is used, and worked when I got it. But, now when I try to start it up, I only hear a clicking noise...and the starter isnt turning over. I found that it is coming from near th battery. I checked both of the fuses, and they werent blown. If you guys can help me at all, then I would REALLY appreciate it! Thanks!
Old Jun 4, 2003 | 10:52 PM
Quadfather's Avatar
Is the battery dead?
Old Jun 4, 2003 | 10:56 PM
MrMan15's Avatar
Well, the lights work, the front ones and the tail lights. We also tried to jump-start it with a car, and nothing happened. So, I dont thinks that is it.
Old Jun 4, 2003 | 11:07 PM
MrMan15's Avatar
im sorry if this is bothering you guys....but I would really like to figure this thing out!
Old Jun 4, 2003 | 11:10 PM
AMCHIEF's Avatar
Did you have the battery out? if you did you may have the wiring wrong. Its easy to do. Also check the wiring to the junk thats just behind the battery. also check those two fuses. hope this helps.
Old Jun 4, 2003 | 11:13 PM
MrMan15's Avatar
I checked the fuses.....I havnt checked the wiring yet, but how do I know if they are messed up? thanks
Old Jun 4, 2003 | 11:19 PM
AMCHIEF's Avatar
Thats hard to explain. if you have a dealer near by go pop the seat on one. I just looked at mine. Pull the wire bundles behind the batt. and check for corrosion. also check where the ground is connected to the frame. it still sounds like a batt. to me. good luck
Old Jun 4, 2003 | 11:23 PM
MrMan15's Avatar
Thanks, Ill check it out. I might just buy a new batt at Wal-Mart or something to see if thats it. Ill also check the wiring to see if anything looks wrong, lol. thanks man.
Old Jun 5, 2003 | 01:48 AM
Hossblur's Avatar
If I am not mistaken the power to run the lights is much less than that required for cranking the starter. Your battery is probably nearly dead, OR The starter may be done.
Old Jun 5, 2003 | 01:52 AM
slowride1's Avatar
I agree with hossblur I had the same problem with my wolv with the clicking . The battery is dead!
